GTS breakdowns
Special X
Got a 60 reg GTS super 300ie and it keeps breaking down (just as I get home from work). If I turn it off when I get home it won't start until the next day. Sometimes it cuts out just as I'm parking it at home and again will not start until the next day. No loose connections, and there's lots of pressure in the injector line. I can only think it's thermal related.
Any Ideas?
I had an intermittent fault on my GTS250i which tuned out to be due to a bad connection in the connector on top of the injector, the plug can bang against the helmet box on full suspension compression which is what started my promelem.
Special X
Cheers that makes sense I'll have a look.
speedy
Sounds a bit of a pain that to me duck. Have you tried changing address to see if that helps. :lol:
Lol
Sent from my GT-I9300 using Tapatalk
e type
Fuel pump overheating prob
    Users browsing this forum: Google [Bot], Semrush [Bot] and 1 guest
