Taffy copy pipe
Donnie
? but the stub on the imola is round and the mugello is standard oval so youre not comparing like for like there
Donnie.
simonwwfc wrote:Why on Muggelo 186 kits is the short black stub fitted and on the Muggelo 200 small block they use the chrome stub any ideas
It isn't?
Imola186/TS1225 etc use the short black/round stub.
Cast Iron, Mugello, Rapido, Avanti etc use the other stub.
simonwwfc
Is it something to do with age of Muggelo kit then ? As mine takes
tonydevon
Main scooter: '71 GP125
thats the normal stub for the muggy kit
my 200 kit was latest version, and uses that shape exhaust port fitting etc
are you confusing muggy and imola?
tonydevon wrote:thats the normal stub for the muggy kit
He seems to be
CPH Lambretta
Main scooter: DL 150 1970
Simon,
Imola/TS1/Monza use a round exhaust port/flange.
Mugello/standard/rapido/RT all use a oval exhaust port/flange.
Question is why do the makers of the exhaust make the 2 different flanges in 2 different lengths?
What you need is an oval flange that is as short as the round flange, if that makes sense.
Slow is the new fast!
Donnie
simonwwfc wrote:Is it something to do with age of Muggelo kit then ? As mine takes
Which is the shape all mugellos take and always have.
Donnie.
simonwwfc
CPH Lambretta wrote:Simon,
Correct :mrgreen:
I'm thinking that getting the manifold cut'n'shut will be the easiest fix.
I've not got one to hand but wondering if you can trim a couple of mm off the stub and off the exhaust pipe to see if it's moving in the right direction?
simonwwfc
Il have stub back tomorrow il post pic and see how it goes from there . If no good looks like andy Francis is next stop
