Whats this for
ukpeckerwood
Main scooter: Vespa PX210
Hi, bought a new 28mm Keihin carb and I dont know what the nipple on the left of the choke is for, Im guessing its for a oil feed and I need to block it off. Image
ukpeckerwood
Just found the answer its a vacuum line and I need to block it off.
Agent Buchwald
Vacuum take off probably but yeah, needs to be blanked off.
Auto lube pipe fits on there
Arborman
Main scooter: RB22
Have a similar one on an OKO!!! Do i need to do the same thing? :)
Although.. what's the set up? Handy for a pump..
storkfoot
It is disappointing that the scooter dealers who sell these Keihin copy carbs do not give clear and precise instructions that this feed must not be left as it is, otherwise your carb will suck in air through it.
ukpeckerwood
The disappointing part is that its a genuine Keihin carb and It comes with zero instructions, I have had Koso PWK copy carbs that came with instructions.
I found this guide on fitting a Keihin to a trials bike useful http://www.splatshop.co.uk/how-to-modif ... -bike.html
