px 200 squish
nam65
Main scooter: t5
Hi all
anybody know what squish a standard 200 should be I keep reading
squish should be around 1.2 -1.5 not sure if this is correct and how
you can reduce it if its greater than that without reworking the head.
any info appreciated
GLscoot
Main scooter: Vespa GS150
Don't know the specs, but if its greater than what you expect, I can't see any other way than getting the head skimmed.
gary
santacama
The standard 200 does not have a squish head system, the head does not have the proper angle to match the piston head. It is possible to raise the compression cutting the head but it will never work with 1 mm distance piston to head because the squish angle, the squish band and the proper combustion dome are missing.
Jack221
Main scooter: PX221
The standard 200 design works fine as it is since the 70's but put in a 60mm crank without any packer or changing anything else. Will feel a bit more torquey and rev a little higher.
santacama
The standard 200 design is archaic.
nam65
Main scooter: t5
cheers all info is much appreciated
Jack221
Main scooter: PX221
santacama wrote:The standard 200 design is archaic.
Yeah, what I said! It's a dinosaur but it works fine
    Users browsing this forum: Majestic-12 [Bot] and 4 guests
