vespa t5 tillitson conversion
ducksta
Well finaly got my tillitson carb conversion finished must say this is the smoothest and most responsive set up ive ever ridden it feels like the cable is not attached when you pull the grip back,internal fuel pump fitted so i can fit my long range tank with no set up problems.
Absolutly no spit back or any spluttering up or down the rev range full test ride today will post later.
soulboy
how much did all that cost
ducksta
havnt got the bill yet
H,POOL GADGE
Main scooter: vespa polini220/gts 300
interesting...
ducksta
the carbs are about £115 had other work done so will itemise if i can
Rich_T
Main scooter: Li Special
Hi, I notice you are using a Tillotson without the choke butterfly, same as a Kart carb. I ran these carbs on Lambrettas a few years ago, although the fuel pump and size is great I found they did not perform as well as a PHBL25 and the problem of cold starting was a pain if you didn't have the choke butterfly. If you ordered a tillotson with the choke butterfly then the venturi was limited to 22 or 23mm as I remember.
I even looked at making my own carb bodies that utilised Tillotson parts with PHBL choke parts and a much bigger venturi. However, when I contacted Tillotson about buying parts they were absolutely less than cooperative about the idea. I even looked at building the carb body into the inlet manifold to save costs.
You can buy a 24mm ventrui Tollotson from here http://www.kartstore.co.uk/shop.cfm?cat=1505&node=129 which is a lot more cost effective.
ducksta
cheers for information m8
GLscoot
Main scooter: Vespa GS150
Well, what was the test ride like?
gary
fastfrog
do you have enough room with your carb aiming at the frame to let your engine swinging?
Size matters!
ducksta
its a smooth ride Gaz, plenty of room Fast Frog and Rich T yes it was a b@5t@rd to start having it finished off this week.
    Users browsing this forum: Amazon [Bot], Google [Bot] and 2 guests
