koso speedo pick up mounted in a speedo worm housing
cezeta
im fitting a koso digital speedo pick up in a speedo worm housing on a scoot rs disc brake. it will be 45 degrees from the magnet. will this be ok?
Fruitjuice
Magnetism doesn't mind angles, it's the distance between the pick up and magnet that matters, so should work perfectly....
Life shouldn't be a journey to the grave with the intention of arriving safely in a pretty, well preserved body, but rather to skid in broadside, in a cloud of smoke, thoroughly used up, totally worn out, loudly proclaiming: "WOW, WHAT A RIDE"
cezeta
cheers, whats inside a murcury switch?
paulmgreen
mercury? :?
www.JPPLambretta.co.uk
its a liquid metal...........that conducts leccy..............and so can be used to make or break a circuit..........dependant on movement.................. :D
sean brady scooters wrote:its a liquid metal...........that conducts leccy..............and so can be used to make or break a circuit..........dependant on movement.................. :D
arnt they used in alarms?
paul-ebsc
and bombs :shock:
fishi
why not using parts directly from KOSO ??
cezeta
they are from koso, im trying to fit the koso pick up in the worm drive hole and mount the magnet in the threaded whatsit thingy that the worm drive is driven by.
because of the angle differance i just wanted to understand the workings incase of issues
    Users browsing this forum: Baidu [Spider], Semrush [Bot] and 20 guests
