t5 malossi porting help needed
soulboy
ok lads im looking at porting and then matching the cases can anybody put some pics up of the best porting areas and how much to take out cheers
fastfrog
could be like this:
Size matters!
jackson85
Main scooter: T5mk1
Your a maniac frog. Leave some metal on the casing
fastfrog
I'll do better next time!!
Size matters!
I find the easiest way is to cut the base gasket to the cylinder then use that to mark the casings with a sharpie
soulboy
cheers
