Autolube
Hammerite
Main scooter: Sx150
I,ve just realised the that the PX engine I,ve bought in bits and about to rebuild is an autolube one. The hole in the casing to the carb has been filled with mastic. Whats the best way to do this properly as I dont want the autolube .Wouldn,t have thought a big dollop of mastic is good enough in the long run. Can I remove the small gear wheel thats the drive for the autolube from behind the clutch
Rich
OzOAP
Main scooter: Vespa PTS1E
You need to keep the gear (or fit spacer from non autolube) as it 'shims' the clutch to engage with the primary.
I thread the hole in the casing and seal with grub screw.
soulboy
mine is done with silicone had no probs
Jack221
Main scooter: PX221
Put chemical metal in mine. I ain't never going back!
Hammerite
Main scooter: Sx150
Thanks for your suggestions fellas
Rich
Train Driver
I love autolube and just wish someone would do a quality conversion for the lambretta
GLscoot
Main scooter: Vespa GS150
You can buy a plug for the axle and it comes with a needle bearing for the small hole, costs about £6.
ducksta
sip blanking plate in mine interfearance fit yes you get to use the hammer :mrgreen:
joeythescooterboy
Go to a plumbers merchant and get a 10mm endfeed stop end....... tap it in and Bob's your Aunty. Costs about 10 bob.
Nemo saltat sorbius, nisi infanus est.
