fastfrog
no still alive in its new form.
Can't get rid of my ST: a foockin addiction now. Mine is running very well knowing it's a pinasco bitza top end....
Size matters!
fastfrog
exhaust porting in progress:
Size matters!
fastfrog
progressing:
Size matters!
fastfrog
close to completion. Still waiting for a decent flange to match exhaust port to it....
Size matters!
fastfrog
a bit polished: it begins to look like it should be:
Size matters!
fastfrog
44,2 mm wide. I guess it's enough for this first attempt.
transfer port through the inlet:
Size matters!
dapper
Been following this thread avidly. Some beautiful porting work going on there.
fastfrog
many thanks. I'm gonna check my squish clearance this WE. Got plenty of head gaskets but need to oversize them to 67,5mm( from 66,5) to proceed to the checking.
Size matters!
fastfrog
meanwhile i had to look after my clutch: an almost fossilized specimen.... Bearing model with a quite devastated basket:
before
after
Size matters!
fastfrog
rebuilding on its way:
gearbox reassembled, perfect play (0,04mm), everything seems to just fit perfectly. My previous grinding op of the layshaft has produced its results: Now the big shim rests on the 1st gear and leaves free the layshaft.
Size matters!
