GT big block experiance : New GT crank info added
eden
mine is
single port 230cc with some mild tuning ive done to bring the timings to what I wanted.
30mm delorto
fran race
4.7 final drive LI150 17x47
Miks is
Standard bridge port 200cc (ports not touched)
30mm delorto
fran race
4.8 final drive LI125 18x47
bazman wrote:What's the graph for the speed mate , is it an App for phone?
Android speedo. its a great little app, In the past ive taped it to the head set to use as a speedo as I ride but as you can record stats from a journey I always have it running in my pocket. It records speed like the graph above, altitude changes and even records the route on a map.
Its does a few other nice things too like max speed, distance travelled, average driving speed etc. etc.
bazman
Cheers Buddy , 8-)
See you C2C?
slangen
Main scooter: TV200
Thanks Eden
If you are on IPhone bazman there is a great pocket app called Pirelli Diablo Super Biker.
eden
bazman wrote:Cheers Buddy , 8-)
See you C2C?
might have to work :( if not ill be there.
bazman
Slangen , no Samsung s4 , just had a look there's tons of apps !!
Eden, will see ya if I see ya lol
bazza3004
eden wrote:As diagnosed......................
kick-start shaft snapped :(
eden the shaft seems to have been ground down on one edge , is this the part of the shaft that needs grinding down when kickstart shaft catches the top steel on clutch ?
eden
ye, its also an old one I found in my s**t f@@ked bits box that at some time in its life had the circlip come off making it move in and rub big time lol
moral here is if your building an engine, even a test prototype engine, don't build it out of old s**t you have lying around on the floor because it will invariably bite you in the ass at some point ;p
bazza3004
bazman wrote:Slangen , no Samsung s4 , just had a look there's tons of apps !!
bazman the diablo biker app is available on android.
bazza3004
eden wrote:ye, its also an old one I found in my s**t f@@ked bits box that at some time in its life had the circlip come off making it move in and rub big time lol
thanks for that :D
slangen
Main scooter: TV200
Will gt200 kit be sold outside the UK, SCK have spare parts for gt186 but no kits, why?
