O-tuning Olivier's px200
fastfrog
case/packer/cylinder porting:
inlet web slighty flowed (not too much to keep a fine balancing without remove too much matter the other side) and advanced (7° more)
Size matters!
wack 63
Main scooter: '71 GP TS1
What tools are you using to port the cylinder?
I like the way that you hook under the closing edge of the crank like i often do also ,it can only help cant it by maintaing intake velocity right up to the last moment and also scoop it in :)
fastfrog
wack 63 wrote:What tools are you using to port the cylinder?
standard carbide cutters, no stone.
sean brady scooters wrote:I like the way that you hook under the closing edge of the crank like i often do also ,it can only help cant it by maintaing intake velocity right up to the last moment and also scoop it in :)
I hooked the inlet back wall too: Hope you can spot it:
Size matters!
GLscoot
Main scooter: Vespa GS150
Completely way over my head, but I am going to follow this thread and see if I can understand whats going on. Sometimes I wish someone would explain this in diddy proof terms.
fastfrog
oups! I'm not clear?
Size matters!
Snapper
Main scooter: Vespa T5 Classic
Great stuff as always,ff! ;)
fastfrog
Hi snapper nice to see you on scooterotica too... I've been doin' porn stuff here for a few weeks...
Size matters!
fastfrog
crank bitza home.
half motovespa (right "motovespa" web) and italian inlet web. The former one has an insane inlet timing with more than 75° ATDC. Unrideable on open streets...So I swaped the left web for a more common 110/55° and worked it to get 124/55°
exhaust wider (+1mm each side) and higher( 1,3mm)
before:
during:
squish checked 2,38mm!!
Size matters!
Jack221
Main scooter: PX221
looking good fastfrog, it's going to fly :D
The exhaust port could still do with another 30 minutes work though. The sides of the port should be more parallel yours enter the bore like a trumpet. If you want to keep the oval top then its your choice!
