Nissin Calipers for Lambretta Disc Brake Kits
Did anyone find out what bike these are originally from?
cartmel808
Might be false - but I'm sure I've read somewhere that they're same calliper as was fitted to Honda NSR125's...
Don't forget if you get a Honda one that it won't fit your light switch housing, they need to be cut, shaped and drilled to fit. Unless your putting it on motorcycle bars.
corrado wrote:Don't forget if you get a Honda one that it won't fit your light switch housing, they need to be cut, shaped and drilled to fit. Unless your putting it on motorcycle bars.
You on calipers or master cylinders?
Ah, now I see the error of my ways. Yes that would only apply to the master cylinder.
Spent a couple of hours searching for a master cylinder earlier so it was obviously still on my mind. That's my excuse and I'm sticking to it.
soullad
Anyone get to the bottom of this?
Are the Nissin callipers a straight swap for the LTH calliper?
