LTH TS1 MANIFOLD- DRILLING?
Rally220
Main scooter: Lambretta S2 TS1 240
Hi all just took delivery of a very nice LTH 30mm TS1 manifold for my TS1 as I want to run a filter under the panels. Upon inspecting it it only has 3 holes for fixing? Is this sufficient or am I going to have to get a 4th hole drilled and tapped in place, see photo's.
Thanks for any replies. Gaz.
My LTH manifold has the 4th hole inside the inlet :? quite a lot of threadlock went on that one :shock:
Rally220
Did it come with the 4th hole already? I'm not sending it all the way back to Germany so I'll either get it done or try myself..... F'in scooter parts always need fettling before fitting!!!!!!!!!!!!!!!!!
Mine did but tbh it isn't machined like yours, more of a cast finish I THINK, I'm not sure if I've got any pics of mine, it was new but I bought from an add on here together with a 30mm BGM PWK.
joespeed
three's ok!
Rally220
Thanks Joe.
MAB
3 is the way forward just seal it well and you will have no issues
3 is the new 4. :mrgreen:
    Users browsing this forum: Ahrefs [Bot] and 4 guests
