Kill switch problem
Jaspvilla
Main scooter: Lambretta Series 2 Li150
I cannot start my rebuild series 1 with the kill switch connected to the cdi, i have check the cabling which is new and resoldered a new pice of wire onto the kill switch which still hasnt sorted the problem.
I cannot see anything wrong with the kill switch, but are they prone to failure? They appear very simple
Is there anything else i should be checking before i purchase a new kill switch
DigDug
Are you sure you aren't shorting your connection to earth?
Did you have to do that?
Jaspvilla
How can i test that?
Connect one contact on a multimeter on beep to green wire between the switch and the cdi.
Connect the other to earth.
You should only get a beep when you press the button. If it beeps any other time you have a short
Jaspvilla
Hi thanks for that, i connected my multi meter, using 20k ohms resistance,green to earth and a short, ie connection, where should i start looking for the short, is it ths switch or a bad earth somewhere?
Does it start if you disconnect that wire from the CDI?
Bear in mind you'll either need to reconnect it while it's running (shock risk) or stall it to stop it if it does.
Been a while since I messed with one with a kill switch, but check between where the green connects to the switch and earth. If it disconnects there try on the terminal and earth.
