Avanti exhaust choice
Minority
Main scooter: Li230 S3
Adam_Winstone wrote:I swapped my JL3 for a Franspeed Supertourer (Avanti type) and found that I'd lost a lot of bottom end and low rev power, to the point that I had to fit an Agusto 6000 to get the bottom back where I wanted it. However, once up the rev range the pipe makes a whole lot more power than the JL3 and it really extends the rev range, and top end.
Up to you. I was happy enough with the combo of Supertourer and Agusto 6000 on my TT3 so this is still my setup on my daily commuter. I wasn't so happy with the Supertourer on the TT3 without the Agusto.
Adam
Hi Adam, at what RPM did the Supertourer start improving over the JL3 (before fitting the Augusto)?
I've got a JL3 on my Rapido 225 and it seems to run out of steam about 7500rpm. I've just fitted a Kytronic SB and was thinking about an exhaust change to either something like the MBGM Clubman for a more standard look or another expansion for a bit more top end (without getting to "racy").
mick1
Main scooter: Li Avanti 225
ducksta wrote:if you had it dynoed then it should of been set correctly?
No. You use the Dyno to identify any problems and confirm if things are aet up correctly (to lean, too rich, timing, etc) then you rectify any problems and re-Dyno. As i knew i was altering the spec' it seemed pointless altering anything (the race exhaust will probably need up-jetting), i just used the Dyno' as a reference point for any changes i make (new exhaust, etc). When i re-Dyno' it will all be then set up correctly.
ducksta
bit of a waste of a dyno then, as i thought you took it to dyno with the components your going to use then have it adjusted to suit.
ducksta wrote:bit of a waste of a dyno then......
Not really, seeing as I didn't charge him for the run.....just did it as a favour as Mick is sound as a pound.
mick1
ducksta wrote:bit of a waste of a dyno then, as i thought you took it to dyno with the components your going to use then have it adjusted to suit.
Without the Dyno how would i know what difference there was between the 2 exhausts ? When your paying "good money" it's nice to see what you're getting.
As Dan had said for the cost he charged i really didn't think i'ld wasted anything ( :D ), plus he identified the sticking choke (bonus !!)
The main reason was to generate a reference point which is what we did.
ducksta
if your not paying then my appologies just so used to having a dyno done after the work.
