Got a t5 engine with a mb cylinder and suzuki piston makes it a 170
Got malossi reeds
28mm dellorto carb
125 main jet
50 idle
X2 needle
Middle line
40 slide
Has power jet in 95
65 choke
Had new clutch seal and resealed carb and checked for leaks (its fine)
Checked timing thats ok 16 btdc
Right the problem is that the engine idles fine but when you pull off just splutters and no go.
When it does rev higher it runs better
Tryed needle on all lines but no go.
When it runs weak choke on full helps
Needs some advice on this set up
Thanks
