nice work ,love the crank mods :)
fastfrog
done with lots of love and sweat.... :D
Crank in place:
Size matters!
fastfrog
barrel rebored and back home.
my test assembly without base gasket gives a very low timing as if MB piston crown height was higher than a standard piston ( ad says no....)
T:108°
E:140°
BD: 16°!!
A pity!!
race-base (http://www.race-base.com)says:
3,2mm packer and 6,6mm to be removed at the exhaust top to get 125/180°
Size matters!
fastfrog
I'm now waiting for a pipe-design silent box to come. Marco Rentzman, the boss, knows how to turn a standard pipe into a civilized expansion. I need the dedicated flange to port the exhaust.
Transfers are finished:
piston could look like this:
Size matters!
TED CRUD
The Piston does not look happy :P
Smash Ya Pastie
Washington Posse s.c
fastfrog
never smile facing the scaffold!
Size matters!
fastfrog
piston operation in progress:
Size matters!
fastfrog
piston ported:
at BDC:
at mid range to the TDC:
from the inside (I like this one!)
Size matters!
rondord
Interesting thread.
How do you think it will compare to this in terms of power output?
http://www.lambretta-images.com/archive ... tta-p2.php
fastfrog
thank mate,
concerning the lambretta-archive thread (one of my favorites) I'm a bit puzzled with the output power gained with this only 2transfert/piston ported engine.... I'll have a dyno asa running in finished....
Size matters!
