Gp headset
drew2
How do you tell the difference between an Italian gp headset and the early Indian slim gp headset??
Would there be any price difference??,thanks
joespeed
from the out side none,italian will cost 1/3 as much again around £150!
mawso
As Joe says visually none, but shims aren't the same size as Italian ones, you need to make sure these were early Indian too, to make it all fit without gaps. Not sure if the shrouds are a slightly different size too.
TS1-200
joespeed wrote:from the out side none,italian will cost 1/3 as much again around £150!
If you are lucky !
Keep on keepin on
