How much?
- drunkmunkey6969
- Moderator
- Main scooter: '69 Lambretta GP
Satellite delay?
- coaster
Yes, single pack acrylic, it is very similar to celly, has a slightly higher 'build' and can be flatted and polished just the same. It's the stuff they put in modern sp ray cans, the downside is that petrol will melt it so if you spill petrol all over your panels, let it dry before compounding the shine back again.....paper towels when still wet is not to be recommendedphilz wrote:Apart from 2pac is there any other safe alternative apart from celly?
2k is indeed nasty stuff but provided you don't use it very often, you use an appropriate 3M mask and have a well ventilated area to spray in you will be fine. The effects of 2k are cumulative though so you do need to be cautious.
- DigDug
- Main scooter: Lambretta
http://www.hse.gov.uk/mvr/bodyshop/isocyanates.htmBifter wrote:You need to spray a lot of 2k paint without a mask for it to kill you
Did you have to do that?
