lambretta gearbox problems
paulr666
Main scooter: lambretta
ok i need help running a li 175 with early type pacemaker li 150 gear box 3rd gear 39 tooth has destroyed its self as they do! i need to replace it but ive read on forums the l8r stronger type does not mesh with the early gear cluster! ive also read that people are replacing these with sx200 37 tooth 3rd gears and the work the same with no problems can anyone confirm this or give me some advice cheers
YAMLAM
this would be better moved to the lambretta Tech section, hopefully admin will pick this up and move it.
win or lose have a booze
