Waterpump
TED CRUD
malossi or Pierburg ,or any suggestions
Smash Ya Pastie
Washington Posse s.c
lloydy
Main scooter: Lambretta DL200
I use the BGM version from MB Developments. Nice bit of kit!
TED CRUD
http://www.lambrettaspares.com/products ... GM0029.JPG
They suggest for a LC head only ,I require one for a 250 cc barrel and head conversion
Cheers Lloydy
Smash Ya Pastie
lambro
I have one of these,
Not identical but by the same maker.
http://www.ebay.co.uk/itm/Davies-Craig- ... 4618534793
LC head and barrel, rad inside the legshields, and keeps it cooler than a cool cucumber on a cool thing.
Shaun.
TED CRUD
Cheers Lambro it looks a good one
Smash Ya Pastie
shilloboxer
I use the craig and bosch one ones and they've worked well for a year pretty much the same size.
Kingwelle
Main scooter: GS2 GS3 Rally200 Primavera et
TED CRUD wrote:malossi or Pierburg ,or any suggestions
My suggestion is to use one of the aditional waterpumps from a BMW 5 or Volkswagen Bus. It's with 12 V as a secondary pump used and conected with fast lock connectors you can adapt to your cooling tubes. I think it's a very cheap way to get a professional cooling pump !
German Ebay- http://www.ebay.de/itm/BMW-5er-E39-Zusa ... 19e725d834
Ebay UK:
http://www.ebay.co.uk/itm/BMW-E38-E39-E ... 1c3ba967a9
Chears,
Michael
tonydevon
Main scooter: '71 GP125
I been looking at the BGM or motoforce unit, BGM is winning at the moment as its sealed from the elements
do you happen to know off hand what the direction of pumping/flow is?
due to where I want to locate the pump I need it to go a particular way.
thanks
tonydevon
http://www.scooter-center.com/product/BGM6300?lang=en
having looked at these pics Im assuming that you would feed water in the axial feed, then it goes out the side hose?
but the impeller doesnt look directional?
Im an aircooled person so this is totally alien to me
TED CRUD
i thought your motor had a internal pump Tony or are you after more power
Smash Ya Pastie
    Users browsing this forum: No registered users and 55 guests
