jocky boxnstop chain tensioner
soupy
hi I have the jocky boxnstop black chain tensioner .I have just fitted this with my new 5 speed. I have it set pushing upwards ,my questions are should I have it tight or allow a little slack ,I have allowed approx 5mm ,I bought this as recommended by rimini but in my case the chain is the correct size for my sprockets,im now thinking maybe over kill as I did have the evergreen top + bottom quick slip guides fitted previously !,cheers soupy
5mm is fine, but yeah, it's sounds like you didn't need to change. Have you seen the new Granturismo one from Rich T?
soupy
soulsurfer wrote:5mm is fine, but yeah, it's sounds like you didn't need to change. Have you seen the new Granturismo one from Rich T?
is that the 1 in this months scootering
I don't think so, it may be in the a Dealer Innovation section on here, I saw it this morning ;)
The readspeed one was in Scootering but both can be found in the dealers innovations section
