exol gear oil
paul213
anyone using this in their gearbox sounds ok no ep addatives
exol Athena Non EP Gear oil SAE 90 API GL1
did a search and could'nt find anything about it
bristolmod
I'm no expert.......but it seems to be the same spec as the original stuff recommended by Innocenti, so should be fine.
No doubt oil technology has moved on a lot,and there may be "better" stuff available, but I can't see any problems.
Chris
Scootering since 1968.
jonashford
I use it no problems
mcbrid
Good stuff
thebassmasta
Main scooter: GP TS1 240
im using maxima mtl85 in mt 6 plate, no problem what so ever
skidmark
Been using it for a while now, same as any other ST 90 I have ever used, no problems.
