BGM stator problems
Noplastic
Main scooter: Vespa PX221 disc
I have another very annoying issue, looks like the headlight unit clips don't hold the bulb holder in place! they don't match, have different shapes ... can anyone tell me which are the right matching parts? here's my holder and here's my unit http://www.scooter-center.com/product/8 ... p*7*7*1*16
http://www.scooterrestorations.com/lamb ... thout-rim/
those clips they break so easily... looks like for every thing i fix theres other 3 breaking down.. :evil: :? :(
Scooter Restorations have good ones. http://www.scooterrestorations.com/lamb ... -clip-cev/
Noplastic
wack 63 wrote:Scooter Restorations have good ones. http://www.scooterrestorations.com/lamb ... -clip-cev/
Thanks Wack. I bought the headlight unit (the one i linked before) from scooter restorations and the clips included with it were crap (probably cause they were indian?)... plus the bulb holder i have doesn't match with it. The plastic tabs of the buln holder don't match the shape of the clips.
What headlight unit-bulb holder combination would you recommend? At this stage i decided to replace everything: headlight unit, bulb holder and key switch and make a definitive job.
This holder http://www.scooterrestorations.com/lamb ... lb-holder/ and the clips should fit the Kace headlight ok
Noplastic
wack 63 wrote:This holder http://www.scooterrestorations.com/lamb ... lb-holder/ and the clips should fit the Kace headlight ok
Thanks a lot! About the key switch how do you remove it from the headset?
The knurled ring screws off.
