Outboard shocks
The pins ar 12mm not 10mm are youtrying to make your own set ?
newboy
Yeah got some shocks with 10mm eyelets
Ok howlong are they are you using them and stripping all the internal stuff out or as an add on I would say 10mm was tosmall to use on there own can the bushes in the eyes be drilled to 12 mm and still have enough wall thickness
