Wiring Loom Length Query - Series 2
PeteB
Main scooter: Lambretta Series 2 Li 150
I'm going to fit a simplified Casa-type wiring loom to my Series 2 as part of a rebuild, with one of them fancy back-to-back brackets for the CDI and regulator that fix to the original coil holes. My query is over the length of the looms available: as a Series 2 has a higher headset than a GP, and the CDI/reg will be mounted higher than the original junction box position, will the simplified non-battery looms generally available be long enough. Or can anyone recommend one that will definitely fit this set-up? Cheers!
cgt75b
Main scooter: lambretta
Nothing wrong with the scooter restorations one, worked for me :D good luck
PeteB
Many thanks for the reco, cgt. I've never had a single problem with anything I've bought from SR over the years, so I'll get one of theirs :)
cgt75b
PeteB wrote:Many thanks for the reco, cgt. I've never had a single problem with anything I've bought from SR over the years, so I'll get one of theirs :)
I'll second that :D no worries
