sip caliper
sjc
iv got a pm tuning front disc brake which uses the grimeca vespa caliper..would i be able to replace this with a sip caliper? cheers steve
Well it's a straight swap on a Vespa ;-)
It's a bit thicker than the Grimeca, so if you have clearance it should be okay. If you post a pic of yours I might be able to tell, unless someone's already done this swap...
martinr
sjc wrote:iv got a pm tuning front disc brake which uses the grimeca vespa caliper..would i be able to replace this with a sip caliper? cheers steve
what colour you after ive got a gold one for sale
wack 63
Main scooter: '71 GP TS1
I fitted one to the PM hub with AF tubeless rims .Just a straight swap.
You'll need a bigger m/c too, or you'll have a lot more lever travel.
Muttley McLadd wrote:You'll need a bigger m/c too, or you'll have a lot more lever travel.
I think it'll be fine, I ran one with a hidden master, I also ran the Stage6 4 pot radial caliper with the hidden master too, no issue whatsoever, in fact, it had a great feel ;)
