Dragster only idles on choke.
Bufficus
My rarely used Dragster has developed a problem where it will only idle with the choke on even when warm. Once off the idle circuit it runs fine.
It has a flip choke conversion on a standard PHVB 20.5 carb, which until now has been faultless.
I assumed it was a blocked pilot jet, but have stripped and cleaned the carb twice, but the problem persists. The reeds appear to be fine.
Am I missing something obvious?
Rich_T
Main scooter: Li Special
Could be an air leak, old fuel?
Bufficus
Thanks for the input Rich.
It has new fuel and no obvious signs of an air leak.
I had another little play today and it seems it won't run at all without the choke.
It hasn't got hot enough for me to suspect it may be electrical, besides I have tried a different CDI and it's the same.
I was wondering if it could be some kind of fuel starvation issue. Although it seems to flow ok if the pipe is removed from the carb. :?
Does anybody know how the automatic fuel tap works on a dragster or how to remove it?
ferritt
works on vacuum i believe, think psn it batley do a manual replacement tap
Bufficus
Thanks I'll give them a call.
