sip speedo question
roadrunnerian
Hi,
i have set up my speedo to the specs i require, will it work ok with out the adjustment button or do i need it to turn it on every time i start it up thanks
Stampede
Main scooter: SX200
No, it works without the button - but you can´t switch through the modes without.
Timbo
It's a challenge fitting the button. Don't think you can fit it between the head set top and bottom (unless they're a bad fit) as they act like a guillotine .. :roll: .....so I've been told..... :oops:
I just threaded it thru the slot I cut for the hydraulic hose
lambro
Timbo wrote:It's a challenge fitting the button. Don't think you can fit it between the head set top and bottom (unless they're a bad fit) as they act like a guillotine .. :roll: .....so I've been told..... :oops:
:lol: :lol:
    Users browsing this forum: Google [Bot] and 9 guests
