PX forks into series 2
wrecklessrobbie
Main scooter: li150
I have seen various vespas with lambretta forks.
Is it possible to put vespa disc forks into a series two lambretta.
Robbie
Not directly but in theory should be possible.
Check this
http://www.ebay.co.uk/itm/301068673195? ... 1423.l2649
wrecklessrobbie
Main scooter: li150
Yes I have seen that. That's a gp frame they are slightly shorter on the steering column aren't they.
They are but a decent welder could sort that out very quickly, do a search on here for fork dimensions.
wrecklessrobbie
Main scooter: li150
The reason I asked the question about PX forks into a series 2 is due to the disc brake.
Piaggio must have developed a disc brake for the p range that works efficiently.
The caliper and disc I presume are specific for the wheel size. Same size as lambrettas. I am wondering will they work on lambrettas. Has any one tried the vespa disc setup ( after modification) on a lambretta
Robbie
Most of the PM hubs would slot right into your series 2 forks and use a more suitable size disk and the grimeca / vespa caliper.
