stalling on take off
scootcoot
Decided to run my 28 dell carb open mouthed ,previously was using a ramfilter ,uped the main jet accordingly, problem is once it starts it hesitates when the throttle is pulled and wants to stall so the revs have to be kept high when i pop into 1st and try to take off it stalls ! would this be to do with the pilot jet or maybe the airmix screw ? 50 pilot, screw 2 turns out.
am a doogal r u a doogal too....!
it would really help to know what motor this is...........?
and also more carb details..............
for eg.............what slide,needle..........and all jet sizes.............
the more info that you can provide............will help us to help you..............
scootcoot
Hey Sean ! LI150 bored to 175, jl3 , 28mm dell, AV264 x7 needle middle clip,125 main ,50 pilot , airmix 2 turns out . :oops:
and the slide is......................?
scootcoot
cant remember the number but the standard slide that comes with the 28mm dell ! i also have a AV268 + AV266 atom + a X13 needle if that helps any ?
for christs sake matey.................just tell us what slide you have in there.................... :lol:
scootcoot
AHHHHhhhh !.... your stressing me out !!! 40 i think :cry: the scoots kept in a garage 1/2 mile away ! Yeah its definately a 40 ! :)
Dazza
sean brady scooters wrote:for christs sake matey.................just tell us what slide you have in there.................... :lol:
:biggrin: :D mr patient
scootcoot
Well after p**s farting around all day trying all different combination of atomizer and needles i finally got it to take off without stalling with a AV268 atomizer and a X13 needle on top clip seem to have done the trick ! :)
thats rich...............it must be well" under" ported./restricted .......... :D
    Users browsing this forum: Google [Bot] and 20 guests
