Best clutch ?
poppygun
Playstation gamer tag: poppygun
Main scooter: GP200 1969
What's the best clutch out there Reedspeed AF race or road LTH MB and so on . At the moment I have a MB deep crown wheel with 5 green plates done about 2000 miles on it but it's starting to slip at high speed so I think it's time for a upgrade so the question is which one . Any thoughts or recommendations will be greatly received Thanks Poppygun
tarmac tickler
APRILIA CONVERSION,, best by far
jonashford
af surflex clutch £440 IMO
What engine/gearing are you running?
You've put better springs in, haven't you?
If money no object....LTH 7 plate.
10 inch Terror
Xbox live gamer tag: No.
AF race, take the old one out, put the AF in and forget about it. The action takes a while to get used too, but once mastered, it's a great clutch.
DigDug
drunkmunkey6969 wrote:If money no object....LTH 7 plate.
What he said... :D
Did you have to do that?
poppygun wrote:What's the best clutch out there Reedspeed AF race or road LTH MB and so on . At the moment I have a MB deep crown wheel with 5 green plates done about 2000 miles on it but it's starting to slip at high speed so I think it's time for a upgrade so the question is which one . Any thoughts or recommendations will be greatly received Thanks Poppygun
Upgrade existing clutch with a Foxhat spider, MB pressure plate, 6 Red plates.
or ........ money no object LTH, fit and forget.
or ......... go mad and contact those nice Foxhat chaps and go up to 8 plates. 8-)
10 inch Terror
It all depends on your engine spec. There's no need to spend more than £100 on anything under 20BHP in my opinion. You can get a Readspeed 5 plate kit for £50 and you can still use all your other standard clutch parts. I'd swap over the supplied springs for MB ones (personal preference) and you'll have a lovely light clutch for very little money. Add the cost of a new clutch cable, oil and chain case gasket and you'll have change from £100. Why over egg the pudding when there's no need to?
MAB
Rocho's clutches are great but NO longer available for a while and also the LTH 7 plate is a fantastic clutch would have to say the best on the market IMO. ;)
    Users browsing this forum: No registered users and 33 guests
