new crank
Train Driver
classic rapido 225, 24mm mikuni and a ancillotti at the moment produces 16bhp and 14lbft torque at 5800 to 6800rpm, what benefit can i expect if i change the crank to a 62mm Mb crank.
Matty
A lighter wallet?
cezeta
Matty wrote:A lighter wallet?
TIGHT ASS
A spare crank?
Train Driver
hopeless answers i am off back to a real forum (LCGB) :lol: :lol:
joespeed
more torque,better for passenger and luggage or possible capable of a little higher gearing leading to better fuel consumption and higher top speed,
regards
joe
Knowledge
Then 24mm carb sounds a bit small for 225cc, and the 62mm will put the capacity close to 250, so I suspect the comments about lighter wallets might include a new carb (28-30mm??). If you are currently running a 58mm stroke, you may need to look at some porting work as the change in stroke is quite dramatic and will leave your porting in no-man's land.
However, longer strokes usually mean more torque, less revs and bigger bangs (from the increased capacity).
Martin
Martin
Train Driver
Thanks joespeed and knowledge all i need now is the right answer from cezeta that he will buy me the crank for Christmas :lol: :lol: :lol:
The engine has been together since 1996 only the top end has been changed so i think it's time i had it apart, well replay or Mb will.
