My scooter seems to have slowed down
a.j
New SR 67 + piston, Delly 28mm carb, reed block, augusto 6000, Kegra pipe, all just fitted, started yesterday, ticks over nicely, feels smooth & it feels like I'm riding a 125!!
WHAT COULD IT BE? :?
ove
Eaten too much over Christmas!!!!
Timbo
Compression..?
You'll need to post some more info to get any meaningful replies, full engine spec, what's been done, what were the weather conditions like, what are you compasring it against?
Weston-scooterist
Main scooter: Lambretta LI150 Special
Have you got your foot on the brake?
psychedelicropcircle
Running through the airbox ? Anything under the seat blocking air?
mick1
Main scooter: Li Avanti 225
Timing ? If you fitted the Augusto did you advance the timing to suit ?
Like a previous reply, more info' will get more in depth replies.
a.j
Run it through the airbox and with the rubber off, no difference. Compression is fine, squish is at 1.5mm. Timing is strobed to suit Agusto. Rode it round the block yesterday and on a straight road for a minute or so through all the gears.
mick1
Leak on primary compression (seals), stuck ring, piston to bore clearance to big, piston in wrong way round, try without Augusto fitted........possible the exhaust just doesn't like the setup and your not getting the rev's to get in the power band (change exhaust)......try these and i'll think of some more !!!
Timbo
The heading is "seems scooter has slowed down" implying it was running fine.
    Users browsing this forum: No registered users and 64 guests
