Wheel Clamp (chock)
GLscoot
Main scooter: Vespa GS150
Im hopefully taking delivery of a hospital bed over the next few weeks and have been looking at wheel clamps so I can secure the scooter on the bed, ideally I would like two, one for the front and one for the rear. Checked the usual places on the net but mostly for motorbikes has anyone used anything else. The rear tyre won't be a problem, I can use blocks of wood , but for the front I would prefer the wheel locked in place.
Cheers
DigDug
Why?
Did you have to do that?
GLscoot
DigDug wrote:Why?
why would you not want to secure the scooter.
If it's not on a slope, why would it move?
Have you got some sort of paddock stand to lift the front wheel off the ground?
DigDug
GLscoot wrote:
DigDug wrote:Why?
I would if I was back in the Navy. ;)
I use a hospital bed based bench and a steel one - never had the need to "secure" scooters when using either of them.
If the stand is off I just use axle stands.
GLscoot
I also use axle stands and car jack for the rear of the scooter. Most of my work is done on vintage scooters with original and modern engines and the stands that are used on these Vespas are no where near as stable as a P range stand and the front wheel is normally only about 2/3mm of the ground. Using axle stands all the time is becoming a pain in the arse, I also have to remove and refit the engines myself. Surely having the front wheel secure and raising the rear of the scooter is much easier and safer. Anyway I really dont see what all the fuss is about Im only looking for a front wheel clamp and was hoping someone has used or got one that works with 10" wheels.
What about one of the lifts designed for crossers? Any use?
Probably cheaper than whatever a scooter shop could sell you to lock the front down.
GLscoot
Crossers!! are these the scissors lift type of things.
Yep. With a flat top.
DigDug
GLscoot wrote:I also use axle stands and car jack for the rear of the scooter. Most of my work is done on vintage scooters with original and modern engines and the stands that are used on these Vespas are no where near as stable as a P range stand and the front wheel is normally only about 2/3mm of the ground. Using axle stands all the time is becoming a pain in the arse, I also have to remove and refit the engines myself. Surely having the front wheel secure and raising the rear of the scooter is much easier and safer. Anyway I really dont see what all the fuss is about Im only looking for a front wheel clamp and was hoping someone has used or got one that works with 10" wheels.
Not making a fuss fella just intrigued as to why someone doing the same thing as me, working on vintage scooters all the time with the same gear needs something else that I've never had a need for. :?:
The one that came with my steel bench works - the type that grips both sides of the tyre. No use with outboard discs though.
Although - I don't do Vespa's... ;)
    Users browsing this forum: No registered users and 63 guests
