Endcans
DigDug
Does messing around with your endcan risk altering the characteristics of the pipe?
I have a Franspeed race pipe on the RB250 motor that Dan built for me but it sticks out about an inch from the back of the scooter which is illegal as far as the BSSO regs go.
Did you have to do that?
I've never found it to make much difference but why not pull that can apart and change the sleeve for a shorter carbon one ? It will make it quieter as well.
Lambrettatastic
are you racing group 4?
DigDug
Lambrettatastic wrote:are you racing group 4?
Six..
DigDug
wack 63 wrote:I've never found it to make much difference but why not pull that can apart and change the sleeve for a shorter carbon one ? It will make it quieter as well.
I'll try that..
Darrell Taylor
Main scooter: LAMBRETTA
regs say no longer than ur bodywork and as its group 6 bodywork is free/ open so you can shorten the silencer or lengthen the bodywork,tie wrap a rubber duck to the back end :D
The duck will come in handy if you find yourself in the lake at Mallory :D
DigDug
Darrell Taylor wrote:regs say no longer than ur bodywork and as its group 6 bodywork is free/ open so you can shorten the silencer or lengthen the bodywork,tie wrap a rubber duck to the back end :D
I did think along those lines Darrell but I must confess the Duck is a new idea.... :D
Darrell Taylor
there is also garfield,or if its red nose month........ buy 2 and make it babboons arse month
