Paint
cgt75b
Main scooter: lambretta
Hello folks
Been toying with the idea of buying a small compressor to try my hand at painting, any clues as to where is the best place to get one, and what kind of price ?
Thanks for any help :D
FATBLOKE
Sorry don't know the answer to the compressor question but when you start painting may be able to get you Wet or Dry at a good price and top quality stuff.
Martin
GLscoot
Main scooter: Vespa GS150
I have been toying with this idea as well. Machine Mart sell them. The cost of all the other additions put me off.
crooky
Main scooter: 1960 series 2 li stg 4 175
A 2hp machine Mart should do you with a cheap gravity fed gun. Small and portable about 120 and 20 for the gun. You can also get a cheap air gauge direct on the gun stops you spraying at too high a psi.
The man who doesn't read has no advantage over the man who can't read
GLscoot
That's not bad. I must have been looking at the pro stuff.
Bifter
Main scooter: vespa p210
The best spray gun would be a HVLP but saying that i have had very good results using this cheap kit http://www.toolstation.com/shop/Compressor+Kit/p11138
It's all in the prep ;)
I used one of these to spray my Gulf themed Jet a couple of years ago http://www.ebay.co.uk/itm/Earlex-HV1900 ... 5af9b8f299
I was amazed at the results, there was some orange peal but that was probably down to me not using the included viscosity cup to get the correct amount of thinners.
Preparation is key to getting a decent finish.
GLscoot
http://www.toolstation.com/shop/Power+T ... 147/p93604
What about this kit, would this be good enough for spraying a scooter and using some air tools. Sorry don't know if the link will work, it may need to be copy/paste
GLscoot wrote:http://www.toolstation.com/shop/Power+T ... 147/p93604
It would be ok for spraying (just) but apart from inflating tyres, it wouldn't be powerful enough to run any air tools, the tank is too small and although they don't state the air delivery rate, with only 15hp, it won't be much.
Bifter
Even rattle cans can turn out good with good prep
Both done with rattle cans
    Users browsing this forum: Google Adsense [Bot] and 7 guests
