I've tried , lots of jetting set ups, had it tested for air leaks , tried ignition retarders and it still does it , so I'm considering changing cylinder head.
The set up is malossi 220 sesc tuned, mmw head with 2.3 mm recess, cases matched, jl pipe and standard carb.
What does anyone suggest to have successfully used on a similar set up???
Ta
