Cyclone 5
weedodger
Main scooter: Indian gp casa 185 and 200
Iv just used the email and submitted my cluster number, for clarification from rimini :?:
I think there's some overall confusion over which batch is which.
As I understand it there's no problem with the first lot, the second batch had a redesigned cluster which if I remember correctly had problems with the pressed on gears slipping. These were recalled and replaced.
The OP said that his had been replaced as part of the recall so that would suggest that it's one of the latest ones.
Perhaps somebody might post a definitive list of the relevant stampings / numbers to clarify the situation?
weedodger
Just got a reply there from dean, mines seems ok,
ssteam177
Main scooter: vba malossi 221, api series2
soullad wrote:
RAP 200 wrote:Not all of them as far as i am aware, the one i have has been faultless , its the upgraded on that has failed .
are you saying this was a batch 3 cluster that failed ?
Both of these were the replacement Xmas trees from the recalled 2 Batch
IT'S NOT WHAT YOU BUY
IT'S WHAT YOU BUILD!!!!
So, effectively batch 3, same as what they're sending out with the current kits?
What's the marking on the cluster?
ssteam177
[quote="rosscla"]So, effectively batch 3, same as what they're sending out with the current kits?
Sorry I can't help with that question as I didn't check the markings once it happened I just wanted to get the parts back to Rimini ASAP and Rimini has it now so I'm unable to find out
Lambretta Sash
Main scooter: Lambretta TV 230
Any updates on gear boxes ?
