Mikuni TM28
mawso
One or two people have mentioned on here and other forums that they prefer not to use the TM 28...difficult to dial in, never ran right, etc.
I've got a new TM 28 that I wanted to use to replace a solid mount Dellorto 28 PHBH.
Does anyone run this carb...not the PWK 28 or ScootRS type, but Mikuni TM 28? If you do what barrel set up do run with it and how is it?
Thanks
red ghost
Main scooter: lambretta gp150
Do a search on here,there was a post a couple of weeks ago regarding these carbs
Robi D
i just switched from a 28 to a 24. i could never get it to work quite right and then when all seemed to be going well, it turns out it was running quite lean. then came issue after issue, i had the new 24 so i just switched to it.
