just rebuilding a mates scooter gp200 engine and noticed that the top ring pin is no were near out as far as the bottom ring pin.
what options do I have ? new hole put in,Or a new pin put in, Its just a std indian top end.
Ta Paul
piston ring peg
might be the the top one is good,and the bottom is coming loose,is it the original piston or a new one.
Tosh
thanks for the replys,as for assuming a cheap piston which is prob correct but I`ve had the same troubles with a peg coming out of an asso piston and messing up my top end up after it had been sorted to 14.65bhp..
and also it is the original piston
