SIP Speedo With Varitronic
I'm sure it's on here somewhere, but there was a lot to wade through from the early days of everyone trying them out, soI thought I'd ask anyway just to be clear.
Is anyone using the SIP speedo with Varitronic, and how have you connected it? Do you have all the functions working, particularly the rev counter and cylinder head temp?
Thanks
Timbo
Was looking at this earlier but not sure it answers your question..
http://www.forums.ilambretta.com/viewto ... fcf8f30493
nelson pk
I've got one running on a varitronic. I powered the speedo via a battery but there is a specific setting on the speedo for using the varitronic. Its mentioned in the instructions what setting to use and they can be downloaded from sip if you look for the speedo on their site.
nelson pk
Just had a quick look at instructions. You need to be on ADJ 4 and change the standard setting which is 3 to 2 for varitronic.
thebassmasta
Main scooter: GP TS1 240
does that include the new kytronic?
thebassmasta wrote:does that include the new kytronic?
The setting for Varitronic is because it sparks twice per revolution, so no, not unless you have a twin spark ignition system.
    Users browsing this forum: Google [Bot], Semrush [Bot] and 9 guests
