gran turismo 200 big block kit
Muppet
big block kit af 48 clubman dellorto phbh 30; need sum jetting help; carb; x7 av268 125main 55pilot; very rich,
C’est la vie
Rich_T
Main scooter: Li Special
For open carb the jetting will be about 125 main (the jetting you have is what has been running for nearly a year now on an open PHBH30 with a JL3 pipe). If you are running through a remote filter it will be less on the main (circa 118 - 120 at a guess but it really depends on the type of remote filter). If you think it is rich I'd start by dropping the needle and perhaps drop the main to a 120, the clubman might be slowing it up a tad too.
Muppet
ilike it loads :P wot sort of mpg shud i get from this kit?
muppet,
C’est la vie
fastfrog
AV268 is the prob try AV264, AV266......
Size matters!
Rich_T
Muppet wrote:ilike it loads :P wot sort of mpg shud i get from this kit?
muppet,
Please confirm, are you running the engine now and is it going well after my previous Email?
Typical MGP from the test engine is 65-70mpg which has a PHBH30 open, a JL3 pipe, stock Indian electronic, 18/47 GP200 gearing and stock casing.
Muppet
Running very well indeedee :P
C’est la vie
So what changed to get it running well?
Muppet
Adam_Winstone wrote:So what changed to get it running well?
nowt rong with it; is runin rich; nice t ride fat powa band lota revs :P new atomisa next
C’est la vie
Muppet
do i need t double up on reeds as on 186 kit?
C’est la vie
lammy57
Hi just got mine on fri looking forward to start building the engine hopefully start on Sunday ! Spec will be mb 58x110 crank ,30 phbh carb, devtour pipe li 150 box going in a series 2 usually 2 up pulling pav so hopefully better torque and better mpg than my ts1 !
    Users browsing this forum: Google [Bot], Semrush [Bot] and 7 guests
