Non driveside bearing
belly
Main scooter: series 2 Li with TS1
What are the pros and cons of using petroil lubrication on non driveside bearing. I know series 1's and early series 2's ran this and I see Super Monza is same
Muppet
constant cool feed of oil/petrol i gess
C’est la vie
and slightly reduced frictional losses maybe
belly
See Mito Racing does a conversion kit to run single oil seal but I would think the mag housing would have to be machined, presumably with a slot running from cut out by transfer. Would it be worth doing on a TS1?
Muppet
mite be reduced friction; gess 1 seal has less friction than 2 seals an bearings run higher rpm in oil than they can in grease cus they run cooler
C’est la vie
    Users browsing this forum: Semrush [Bot] and 10 guests
