Modern Gearbox oils
Grumpy225
hydra wrote:Dopeshots,
Maxima MTL 85 is a GL3 Gear Oil, which means it has mild EP additives. These additives offer more protection to mating parts by creating a chemical barrier between Gears etc. As a comparison Rock Oil ST90 is a GL1 oil and as such as no additives other than anti-foam etc. Just to be clear, EP additives do not create Clutch slip. Another GL3 Gear Oil is Castrol's ST90.
And just to finish with a little advertising, Scooterotica, Chiselspeed and MB endorse and sell Maxima Oils.
Cheers, Paul Gillow, Oiltek
I agree, been using MTL 85wt for years now. It's cheap, works great, no clutch or shift problems and can pick it up locally.
hydra wrote:The multi grade gear oil will be ok as long as it is GL1,2 or 3 anything above will probably attack silver/bronze parts in your gearbox.
Cheers, Paul Gillow - Oiltek
Fek, just checked what I put in my TS1 gearbox, Halfords Motorcycle 80/85 GL4......might account for some of the slipping :oops:
GP Kevo
Used MTL-E 85 wt in my TS1 in the States. Excellent gear oil.
jedan71
Xbox live gamer tag: Jedan71
Sorry for jumping on an old post, but here in New Zealand we get a product called spectro wet clutch oil, with 10~30w, for use with 2st motocross bikes, could this be used as Lammy gear oil...? It is ma & ma2 Jaso approved
Sent from my GT-I9505 using Tapatalk
jedan71
Called Spectro Sx clutch saver sae 10~30w. Made in the USA
hydra
jedan71 wrote:Called Spectro Sx clutch saver sae 10~30w. Made in the USA
Jaso MA spec will work with the clutch, if anything 10w/30 is a little light, would be better if it were 10w/40, but I'm sure it will be ok, it's roughly equivalent to an 80 weight gear oil which Vespa's use.
immylam
Just fitted a Saigon scooters 5 plate clutch , what oil would be best to use with this as the plates are different from usual lammy ones?
Train Driver
Motul Gear 300 75W-90
    Users browsing this forum: Baidu [Spider], Semrush [Bot] and 3 guests
