Universal Replacement End Cans
Tommy Boy
Main scooter: Series 1 with a Twist!
Do these come with the baffles packed already?
M.D.M.A. Scooter Collective
tSR-VN
corrado wrote:Are they as heavy as the SSC Taffy style ones? It looks like the same item.
The taffspeed type fitment can has a different stud pattern.
Ive done some of these too with a lambretta stamp - same price.
They also fit the MB DEVTOUR pipes.
Weight is around 850g per can - Before making these cans we tested various different end-can designs and came to the conclusion that this was the best one in terms of noise level as well as ability to easily repack. I think the weight is ok.
tSR-VN
Tommy Boy wrote:Do these come with the baffles packed already?
Yes mate they are bolt on good to go.
We have just discovered that the "sterling" pipe stud design despite looking like the PM is actually a little off so if you are lucky enough to own a sterling pipe unfortunatly these cans wont quite work on them.
In other news we have a new lambretta expansion pipe built by us and designed and dyno developed by Marco Rentzmann of Pipe-design.de
10 inch Terror
Xbox live gamer tag: No.
Are you still doing these? I sent you an inquiry PM a month ago and you didn't reply.
tSR-VN
10 inch Terror wrote:Are you still doing these? I sent you an inquiry PM a month ago and you didn't reply.
The End-cans? yes mate certainly. We have all the 3 types mentioned above in stock at the moment.
Send me a mail to thescooterrepublic AT gmail DOT com and will sort you out.
    Users browsing this forum: Semrush [Bot] and 60 guests
