T5 cylinder
Chris H
I've got an old T5 cylinder that has been seized and now has damaged plating. Can it be rebored, replated, and a bigger piston used or just replated and use a standard piston.
roadrunnerian
Hi m8 you can have them replated or see if there is a 2nd hand one for sale,or buy a kit polini,malossi or try martin at chiselspeed he is very helpfull hope you get sorted m8
gaz_powell
you could bore it out, replate it or steel line it and use a suzuki TS185 piston
Chris H
gaz_powell wrote:you could bore it out, replate it or steel line it and use a suzuki TS185 piston
This sounds just the job, if I remember correctly Mark Broadhurst used to offer something similar in the late 80's. The next question is would it work with a box exhaust and up jetted carb?
gaz_powell
MB still does them equally chiselspeed or JB Tuning would do it.
or as already said take a polini barrel and bore it again use a TS185 piston
good luck
cezeta
box pipe and standard carb works perfectly
gaz_powell
you will need to rework the head if you use a ts185 piston
Chris H
Thanks for all the advice lads really appreciate it. I've decided to go for it and will let you know how I get on.
ducksta
i have the suzuki conversion done by chislespeed top job
