Is it worth fitting a 65 primary to a PX125
GLscoot
Main scooter: Vespa GS150
I have my casings split and was wanting to know the benefits of fitting a 65 tooth primary and a 22 tooth SIP strengthened clutch. With the primary can I remove the 68 and fit the 65 or do I need the complete unit.
Thanks Gary
Jack221
Main scooter: PX221
I can't imagine a PX125 that would ever pull 4th with gearing that high!
Vespa est ieiunas, quia semper operaturi
GLscoot
Is this not what the forum is about, someone had suggested this set up to me, so i decide to post the question on hear as i didn't know if it would work. So now i know.
joeythescooterboy
No mate, a PX struggles to pull the standard 20/68 primary, raising it would be a bad idea.
GLscoot
Yes I know, I won't be going down that road sticking with the 68.
125 barrel, or just 125 cases?
With a half decent kit on it, it should pull 23/65 with ease.
GLscoot
125 matched casings to polini 180, worb5 flowed reed crank, reed valve and 28 or 26mm dellorto carb and sip cosa2 clutch 22 or 23 depending on the primary. after talking to a few people now i think i will stick to the 68 primary and the 22 clutch
Are you putting a super revvy pipe on it?
GLscoot
the two pipes i have are the sip and gianelli. will try them both and see which one is better, may even try the bgm
Are you undergearing it for a reason?
Your kit should pull 4.8, two up, with ease. Esp with a SIP road on it.
