PX 58mm stroke crank
ducksta
will pop over to run my eye over it for you we all know what happend last time you got the spanners out when my back was turned.
mick1
Main scooter: Li Avanti 225
Bearing in mind this might be the solution for a Vespa to keep up with the York Avanti Riders.....
ducksta
we will see, project x in the pipe line avantis ive s**t em :D
goldeneye
you"d struggle to get an Avanti barrel and head to fit in the frame ,they have much fatter fins than a standard lammy barrel.
mick1 wrote:Bearing in mind this might be the solution for a Vespa to keep up with the York Avanti Riders.....
No, you are thinking of an alloy Polini 210 with a Mallossi Piston, long stroke crank, Scooterotica porting job, and a decent pipe.....lol.
But I like your project better.... ;)
ducksta
shhhhhhhhh Dan keep me updated on Micks build want to know what ime up against :D
ducksta
goldeneye wrote:you"d struggle to get an Avanti barrel and head to fit in the frame ,they have much fatter fins than a standard lammy barrel.
obviously you dont know Mick or mick the grinder we call him :D :D
ducksta wrote:....... or mick the grinder we call him :D :D
Sounds like his stage name in an Amsterdam sex show. :shock:
I would imagine..... :roll:
:lol: :lol: :lol:
ducksta
the bar was called the blue oyster bar if i remember
mick1
ducksta wrote:the bar was called the blue oyster bar if i remember
Sigh............ok Ducksta if you want to go down that road.
Kindly explain why you were naked on Brighton beach with another man ? :oops:
Kindly explain why you then accepted a lift, whilst still naked,from a complete (male) stranger ? :oops:
Kindly confirm that you and the second naked man on Brighton beach both had "Magnum" tashes......and it wasn't November. :roll:
Kindly confirm, so there is no doubt what-so-ever that you are a Vespa rider :o
I patiently and with wry amusement await you reply...... :mrgreen:
