PX 58mm stroke crank
mick1
Main scooter: Li Avanti 225
Is there a 58mm stroke crank readily available for a large block PX or does anyone know who can build one (rough guide price?).
Thanks
santacama
Not that I know. What do you need it for?
mick1
Considering a Lambretta cylinder on PX casings and was trying to match the Lambretta crank/stroke. Probably not critical but looking at options.
ducksta
martin at chislespeed will build you one if it can be done
mick1
Too much hassle, plus spares/replacements might be an issue.......going with an "off-the-shelf" 60mm
ducksta
so whats the spec mick and is QMT building it?
mick1
It's looking like a 60mm stroke Avanti 225 (get the kit tomorrow) on PX casings
Still to be decided:
Exhaust
Electrics
Clutch
Gearing
.....and whether to mount carb on barrel or casing ?
It'll be a QMT build
QMT are building 2 other Avanti kits as well (Lambrettas) so don't know when the Vespa will get built.
goldeneye
P2 crank is 57mm stroke standard. why not just get a Quattrini or a polini alloy 220? if I was doing a daft barrel conversion, I"d be using T5 casings , as they are "square", as opposed to having the barrel on the p155 like a P2. nice fat crank webs and big ports in the casing. the quattrini 172 on px125 casings looks like the better option. unless you wanna do it for the craic .
mick1
I've about 1/2 a dozen p2 casings so that's why i'm heading in that direction. I've had an Avanti on my lambretta for about 2 years and really impressed, thought it would be nice to see if it could be replicated on the P2. Loads of P2 engine bits as well........but the craic plays a large part :D
goldeneye
nee bother , sounds like a canny project. sell the p2 casings and buy some T5 ones then! and get ya ally welder a nice xmas present..... ;) :D
